I’ve been migrating our Redshift data source from good old Postgres plugin to Redshift plugin.
I noticed that variables don’t work as expected for the case when we were using __text and _value. I’m wondering if support for this feature might be missing in the Redshift plugin (and would hope for a hint to be able to contribute).
Any help, why this is not working is much appreciated.
10.2.2 -
Use the Redshift plugin and have a query variable similar to
SELECT 'myvalue' AS __value, 'mytext' AS __text
I then want to show the __text to the user, but query data based on the __value.
- What happened?
The variables text AND value is the first column returned.
${var:text} should be mytext, ${var:value} should be myvalue,
See in the screenshot, which should actually show mytext as value preview:
In comparison, see a custom variable defined as mykey : myvalue
I found this topic here, which describes the same problem, but the “solution” doesn’t work for me.
