structuredMetadata vs label escaping
I’m using Grafana Loki for storing logs. I am using structuredMetadata for faster lookup. I’m ingesting and reading data to/from Loki via http API. When I want to query by some structuredMetadata that contains escaped characters, I have to use a different expression than the one I use in label query expression, although I’d expect that both expressions should be the same.
For example, I ingest one record with one label label: "value and one structuredMetadata struct_metadata: "value (both contain double quote) using this request (JSON payload):
POST <loki-gateway-host>/loki/api/v1/push
  "streams" : [ {
    "stream" : {
      "label" : "\"value"
    "values" : [ [ "<unixEpochNanoseconds>", "<logLine>", {
      "struct_metadata" : "\"value",
When I want to query all events with this label and with this struct_metadata, I send request GET <loki-gateway-host>/loki/api/v1/query_range with this query param:
{label="\"value"} | struct_metadata="\"value"
The stream selector using event_source="\"label-value" correctly filters records with label value "label-value. However, the structMetadata filter expression does not work. I have to change the query to
{label="\"value"} | struct_metadata="\\\"value"
In other words, I have to add extra backslash.
Is that expected behaviour? Why the label value can be compared without extra escaping / why the structMetadata value must contain extra escaping?
Thank you for your response!
Try wrapping the label value filter into single quotes or into backticks instead of double quotes:
{label='"value'} | struct_metadata='"value'
Hi! Thank you for the suggestion. Singe quotes are invalid (invalid syntax), only double quotes or backticks can be used. I have tried backticks but it behaves the same as double quotes.
I have noticed that Loki treats label values escaping differently from struct_metadata values, it may not be a problem of incorrect query. For example, if you push this:
  "streams" : [ {
    "stream" : {
      "label" : "\"value"
    "values" : [ [ "1749031169275416000", "whatever", {
and then search by query
you get in response
    "status": "success",
    "data": {
        "resultType": "streams",
        "result": [
                "stream": {
                    "detected_level": "unknown",
                    "label": "\"value",
                    "service_name": "unknown_service",
                    "struct_metadata": "\\\"value"
                "values": [
                        "whatever"
        "stats": {
Correct me if I’m wrong but I think that this is a bug. In my opinion Loki incorrectly stores struct_metadata value as "\\\"value" although it should be stored as “"value” (same as label value).
I’ve come across this too.
this is what is posted…
“values”: [
“1769692413542360000”,
D:\\Shares\\SomeFile”,
“UpdateTime”: “29/01/2026 18:43:33”,
“FileName”: “SomeFile.pdf”,
“CreateTime”: “29/01/2026 18:43:33”,
“Flags”: “5”,
“FileHash”: “45982fa20c62e3e2 036421cb1c808544”,
“FullPathName”: “D:\\Shares\\SomeFile.pdf”,
“Attributes”: “32”
But in the grafana query endpoint /api/ds/query?ds_type=loki I get the following
“data”: {
“values”: [
“Attributes”: “32”,
“Flags”: “5”,
“FullPathName”: “D:\\\\Shares\\\\SomeFile”,
“detected_level”: “unknown”,
“host”: “SR1DR”,
“job”: “klaw-dfsr-dr-test11”,
“service_name”: “*******************”
[1769692413542],
[“D:\\Shares\\SomeFile”],
[“1769692413542360000”],
“Attributes”: “S”,
“CreateTime”: “S”,
“FileHash”: “S”,
“FileName”: “S”,
“Flags”: “S”,
“FullPathName”: “S”,
“UpdateTime”: “S”,
“detected_level”: “S”,
“host”: “I”,
“job”: “I”,
“service_name”: “I”
[“1769692413542360000_d0995a00”]
I also see a similar bahaviour when querying loki directly via /loki/api/v1/query_range. The “\” is double escaped in the metadata but not in the line itself.
I hope this helps.
