Strange NoData alerts
using Grafana alerts with Threema Gateway to monitor a self scripted node exporter for some services throws the following alert every four hours:
⚠️ [FIRING:1] DatasourceNoData Alert rules (fdi74e1dtwkcge A Service failed)
Message:
**Firing**
Value: [no value]
Labels:
- alertname = DatasourceNoData
- datasource_uid = xxxxxxxxxxxxxx
- grafana_folder = Alert rules
- ref_id = A
- rulename = Service failed
Annotations:
- summary = Service failed
Source: http://localhost:9091/alerting/grafana/xxxxxxxxxxxxxx/view?orgId=1
Silence: [http://localhost:9091/alerting/silence/new?alertmanager=grafana&matcher=alertname=DatasourceNoData&matcher=datasource_uid=xxxxxxxxxxxxxx&matcher=grafana_folder=Alert+rules&matcher=ref_id=A&matcher=rulename=Service+failed&orgId=1](http://localhost:9091/alerting/silence/new?alertmanager=grafana&matcher=alertname%3DDatasourceNoData&matcher=datasource_uid%3Dxxxxxxxxxxxxxx&matcher=grafana_folder%3DAlert+rules&matcher=ref_id%3DA&matcher=rulename%3DService+failed&orgId=1)
URL: http:/localhost:9091/alerting/list
This seems to me like a bug because the silence URL is not correct here (other messages have the correct URL https://my-fqdn.tld/…) and silencing does not show any effect. The alarm is fired again though.
Prometheus shows that the used node exporter works fine. The configuration of the alert is attached (did not work because i’m a newbie, so i had to post it inline).
It would be great if you could help me stopping these alerts.
Best regards
Andreas
apiVersion: 1
groups:
    - orgId: 1
      folder: Alert rules
      interval: 1d
      rules:
        - uid: fdqf1l3qi4idcd
          title: Reboot required
          condition: C
          data:
            - refId: A
              relativeTimeRange:
                to: 0
              datasourceUid: xxxxxxxxxxxxxx
              model:
                editorMode: code
                expr: node_reboot_required
                instant: true
                intervalMs: 1000
                legendFormat: __auto
                maxDataPoints: 43200
                range: false
                refId: A
            - refId: C
              relativeTimeRange:
                to: 0
              datasourceUid: __expr__
              model:
                conditions:
                    - evaluator:
                        params:
                            - 0
                            - 0
                        type: outside_range
                      operator:
                        type: and
                      query:
                        params:
                            - C
                      reducer:
                        params: []
                        type: last
                      type: query
                      unloadEvaluator:
                        params:
                            - 0
                            - 0
                        type: within_range
                datasource:
                    type: __expr__
                    uid: __expr__
                expression: A
                intervalMs: 1000
                refId: C
                type: threshold
          noDataState: OK
          execErrState: Error
          for: 0s
          annotations:
            summary: Reboot of VM is required after automatically APT updates
          isPaused: false
          notification_settings:
            receiver: grafana-default
        - uid: xxxxxxxxxxxxxx
          title: Service failed
          condition: C
          data:
            - refId: A
              relativeTimeRange:
                to: 0
              datasourceUid: fdi74e1dtwkcge
              model:
                disableTextWrap: false
                editorMode: builder
                expr: node_services
                fullMetaSearch: false
                includeNullMetadata: true
                instant: true
                intervalMs: 1000
                range: false
                refId: A
                useBackend: false
            - refId: C
              relativeTimeRange:
                to: 0
              model:
                conditions:
                    - evaluator:
                        params:
                            - 0
                            - 0
                        type: outside_range
                      operator:
                        type: and
                      query:
                        params:
                            - C
                      reducer:
                        params: []
                        type: last
                      type: query
                      unloadEvaluator:
                        params:
                            - 0
                            - 0
                        type: within_range
                datasource:
                    type: __expr__
                    uid: __expr__
                expression: A
                intervalMs: 1000
                refId: C
                type: threshold
          noDataState: NoData
          execErrState: Error
          for: 0s
          annotations:
            description: ""
            runbook_url: ""
            summary: Service failed
          labels:
          isPaused: false
You can change
to
     noDataState: KeepLast
you can read more about possible options in the documentation
As far as URLs are concerned, I agree that seems to be a bug. Can you open an issue in GitHub?
Also, please mention the version of Grafana.
Dear @yuriy.tseretyan, thanks.
I’ve already changed the configuration as proposed to stop these quite annoying alerts. But this is not a “real” solution because i’d like to be informed about real NoData alerts.
So i opened an issue: Alerting: Strange NoData alerts · Issue #90447 · grafana/grafana · GitHub
