Hello!
I am migrating a dashboard from simplejson datasource to infinity data source and one of our tables keeps showing the message “Data outside time range”
I have noticed some weird interactions with this.
This is a timeseries using a set time span (usually past 14 days) past 7 days works fine
it breaks past 8 days.
Any data subset ( using the legend on the right) does not show the “Data outside time range” message
When I try to “Zoom to Data” the graph takes me to an impossible time range with the from after the to date
- The actual data being shown behind the message is correct and exactly what I would expect!
version 11.3.0, windows, microsoft edge -
I am recieving data in a format that looks like this:
"data": [
"metric": "RS",
"time": 1738450800000,
"value": 9
"metric": "AT",
"time": 1737586800000,
"value": 8557
"metric": "AT",
"time": 1737673200000,
"value": 119924
"metric": "AT",
"time": 1737759600000,
"value": 4089
I am using a short UQL query to get the data to show in the time series:
parse-json
| pivot sum("value"), "time", "metric"
The table view does not show any irregularities
The effects are the same whether or not I use query options to set the time span or use the dropdown at the top to set it
The “Data outside time range message” and this console error which I am unsure is related as it does not appear when refreshing the data
no
Honestly if there was a way to just disable the message pop up I would do that, but if there is a configuration or query error that would interest me as well.
Thank you for reading this post!
