Storage schema changes
Hi
I have modified my storage scheme changes to
[default]
pattern = .*
retentions = 30s:1d,5m:5d
and i ran these,
find /opt/graphite/storage/whisper -type f -name “*.wsp” | xargs -I{} whisper-resize.py {} 30s:1d 5m:5d
and restarted the services. But, even after that data is getting deleted after 24h.
Is there a way to correct this. Kindly suggest.
Make sure whisper resize worked , check using whisper info util
