Step 1: Open Your Loki Alloy Configuration File
Command: sudo nano /etc/alloy/alloy-config.hcl
Step 2: Replace with the Correct Configuration
loki.source.file “logs_gitlab_01” {
targets = [
{“path” = “/var/log/gitlab/gitlab-rails/production_json.log”},
forward_to = [loki.process.logs_gitlab_01.receiver]
loki.process “logs_gitlab_01” {
stage.json {
expressions = {
extracted_status = “status”,
stage.labels {
values = {
“status” = “extracted_status”,
stage.match {
selector = “{status=~"2[0-9]{2}"}”
stage.labels {
values = {
"level" = "info",
forward_to = [loki.process.logs_gitlab_00.receiver]
Step 3: Save and Exit
After pasting the configuration, do the following:
- Press CTRL + X (exit editor).
- Press Y (to save changes).
- Press Enter (confirm the filename).
Step 4: Restart Loki Alloy
Command: sudo systemctl restart alloy
Step 5: Verify If Alloy Is Running Properly
Command: sudo systemctl status alloy
Step 6: Verify That Filtering Works in Loki
loki query ‘{status=~“2[0-9]{2}”}’
