@anon34853223, Hope this message finds you well. I don’t know whether you have any way to contact the contributor of the Status Dot Panel which is bptlc or not. I have 1 issue need to be figured out, could you please help me out with this? Great thanks…
Continuing the discussion from Status Dot Panel Issue:
Answered in one of your other issues. All the BT plugins are in GitHub repos and you can create an issue there.
Yeap. I’ll try that. Thanks a lot and happy Chinese New Year !
