Staircase line and normal line in one graph
Hi All,
Cannot find it in the docs.
Is it possible to combine a staircase line and a normal line in one graph. This to display ‘room temperature’ (normal line) and ‘room target temperature’ (staircase).
Thx,
PPee
Yes, you can definitely do this by using series override. As you can see below, I have added staircase line to cpu metric and kept normal line for memory.
Thx Ivana, great, that worked
