I’m pretty new to Grafana and Data Base manipulation. I’m trying to create a BarCharts which represent the amount of parts produced for each Parts Type. I need to stack the bar and I can’t find a solution to do it
v9.4.10 -
Stack bar in a Bar Charts. -
That’s the question -
What happened?
Impossible to find a solution to stack bar. Here is my result for now :
Exemple here made with Excel :
`DECLARE @start DATETIME
DECLARE @end DATETIME
DECLARE @offsetDay INT = 0
IF (SELECT DATEPART(weekday,GETDATE())) = 1
SET @offsetDay = -2
SET @start = (SELECT DATEADD(dd, @offsetDay, DATEDIFF(dd, 0, GETDATE())))
SET @start = (SELECT DATEADD(hh,-19, @start))
SET @end = (SELECT DATEADD(dd, @offsetDay, DATEDIFF(dd, 0, GETDATE())))
SET @end = (SELECT DATEADD(hh,5,@end))
SELECT
TypeID,
COUNT(*) as Real_Prod
FROM
L7DAE.dbo.OP7300
WHERE
LeaveDate BETWEEN @start AND @end
AND PartState = 1
GROUP BY
TypeId
ORDER BY MIN(LeaveDate) ASC `
- Did you receive any errors in the Grafana UI or in related logs? If so, please tell us exactly what they were.
No - Did you follow any online instructions? If so, what is the URL?
No
Thanks in advance for your help !
