I’m trying to figure out how to have stacked time results for a query such as:
SELECT __timeEpoch(time_stamp),
retry_percent as value,
config_name as metric
FROM
dbo.AER1600_eth_tcp_1
WHERE
__timeFilter(time_stamp)
ORDER BY
time_stamp ASC
There are 2 tables in question, that have the same field names, dbo.AER1600)_eth_tcp_1 and dbo.AER2200_eth_tcp
How can I write a query for a dashboard that will stack the results for each of these tables??
I think you should try with an INNER JOIN something like that :
SELECT
__timeEpoch(time_stamp), dbo.AER1600_eth_tcp_1.retry_percent as value, dbo.AER1600_eth_tcp_1.config_name as metric
FROM dbo.AER1600_eth_tcp_1 INNER JOIN ON dbo.AER1600_eth_tcp_1.config_name = dbo.AER2200_eth_tcp.config_name
WHERE __timeFilter(time_stamp)
ORDER BY
time_stamp ASC
Just correct column where you make the JOIN between the two table.
You work with MSSQL right ?
