We have an issue where a specific log suddenly disappears.
Below is the configuration file installed on the Windows Server VM
integrations:
prometheus_remote_write:
- basic_auth:
password:
username:
url: https://prometheus
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- action: replace
target_label: job
metric_relabel_configs:
- action: keep
regex: (prometheus_target_.*|prometheus_sd_discovered_targets|agent_build.*|agent_wal_samples_appended_total|process_start_time_seconds)
source_labels:
- __name__
windows_exporter:
enabled: true
instance: XRF-PROD # must match instance used in logs
relabel_configs:
- target_label: job
replacement: 'integrations/windows_exporter' # must match job used in logs
logs:
configs:
- clients:
- basic_auth:
password:
username:
url: https://logs
positions:
filename: "D:\\tmp\\positions.yaml"
scrape_configs:
- job_name: integrations/windows-exporter-application
windows_events:
use_incoming_timestamp: true
bookmark_path: "C:\\Program Files\\Grafana Agent\\bookmarks-app.xml"
eventlog_name: "Application"
labels:
job: integrations/windows_exporter
instance: XRF-PROD # must match instance used in windows_exporter
relabel_configs:
- source_labels: ['computer']
target_label: 'agent_hostname'
pipeline_stages:
- json:
expressions:
source: source
- labels:
source:
- job_name: integrations/windows-exporter-system
windows_events:
bookmark_path: "C:\\Program Files\\Grafana Agent\\bookmarks-sys.xml"
eventlog_name: "System"
labels:
- job_name: composer-logs-job
static_configs:
- targets: [localhost]
labels:
instance: XRF-PROD
job: composer-logs
__path__: "D:\\UNIRITA\\SmartConductor\\plugin\\xrf_composer\\log\\composer.log"
- job_name: xrf-logs-job
static_configs:
labels:
instance: XRF-PROD
job: xrf-logs
__path__: "D:\\XRF\\log\\xrf_log.log.0"
metrics:
configs:
- name: integrations
remote_write:
- basic_auth:
password:
username:
scrape_configs:
global:
scrape_interval: 60s
In the Grafana Cloud UI, the two log locations are visible:
However, after a day or two, one of the logs D:\UNIRITA\SmartConductor\plugin\xrf_composer\log\composer.log is no longer visible.
Rebooting the Grafana agent service doesn’t resolve the issue. You have to reboot the server for the logs to reappear. But after a while, it’s gone.
Your help is greatly appreciated.
