I have read most of the documentation that is available for installing Grafana for Windows. My teams are using a Windows VM/VMSS infrastructure in Azure without Kubernetes. I have installed the Grafana agent and attempted to modify the agent-config.yml based upon forum messages and Grafana site documentation, and I am unable to send any logs to Loki. We did a curl command to check for connectivity, and that passed. I’m hoping to get more detailed help with the agent-config.yml. Below is the only .yml file that will allow me to start the Grafana Agent service, but it does not populate the positions directory or logs file, and nothing is sent to Loki.
agent-config.yml:
server:
log_level: debug
prometheus:
wal_directory: "C:\\ProgramData\\grafana-agent-wal"
global:
scrape_interval: 15s
remote_write:
- url: https://prometheus-prod-13...
basic_auth:
password: <password>
username: <username>
configs:
- name: integrations
integrations:
windows_exporter:
enabled: true
loki:
positions_directory: "C:\\Users\\azureuser\\Logs"
configs:
- name: windows
clients:
- url: https://grafana-loki...
tenant_id:
basic_auth:
- job_name: windows
windows_events:
bookmark_path: "C:\\Users\\azureuser\\bookmark\\bookmark.xml"
use_incoming_timestamp: true
eventlog_name: "Application"
xpath_query: '*'
labels:
job: windows
Facing similar issue in windows VM, try to get the Grafana Agent logs from Event Viewer.
@sandeepshajan21 I am working on logs now. I will post if I find a workable yml.
Metrics can be gotten using the following in the agent-config.yml:
integrations:
prometheus_remote_write:
- basic_auth:
url: https://prometheus-prod URL
windows_exporter:
enabled: true
logs:
configs:
- clients:
- basic_auth:
url: https://loki URL
positions:
filename: /tmp/positions.yaml
scrape_configs:
- job_name: integrations/windows-exporter-application
pipeline_stages:
- json:
expressions:
source: source
- labels:
source:
relabel_configs:
- source_labels:
- computer
target_label: agent_hostname
windows_events:
bookmark_path: C:\Users\azureuser\AppData\Roaming\bookmark-application.xml
eventlog_name: Application
labels:
job: integrations/windows_exporter
xpath_query: '*'
- job_name: integrations/windows-exporter-system
pipeline_stages:
- json:
expressions:
source: source
- labels:
source:
relabel_configs:
- source_labels:
- computer
windows_events:
bookmark_path: C:\Users\azureuser\AppData\Roaming\bookmark-system.xml
eventlog_name: System
labels:
xpath_query: '*'
target_config:
sync_period: 10s
metrics:
configs:
remote_write:
- basic_auth:
global:
There is a very good dashboard for metrics which requires the windows_exporter.msi here:
Windows Exporter Dashboard | Grafana Labs
@sandeepshajan21
This is the basic Grafana agent-config for Grafana agent integration for Windows event logs if you also use the windows_exporter:
integrations:
agent:
enabled: true
relabel_configs:
- action: replace
source_labels:
- agent_hostname
target_label: instance
- basic_auth:
password: <your_prom_pass>
username: <your_prom_user>
url: <your_prom_url>
logs:
configs:
- clients:
- basic_auth:
password: <your_loki_pass>
username: <your_loki_user>
url: <your_loki_url>
positions:
scrape_configs:
- job_name: integrations/agent
windows_events:
bookmark_path: "./bookmark-application.xml"
xpath_query: "*[System[Provider[@Name='Grafana Agent']]]"
labels:
job: integrations/agent
relabel_configs:
- source_labels: ['computer']
target_label: 'instance'
- replacement: grafana-agent.service
target_label: unit
pipeline_stages:
- json:
expressions:
message: message
- regex:
expression: "(level=(?P<log_level>[\\s]*debug|warn|info|error))"
- labels:
level: log_level
- output:
source: message
metrics:
configs:
- name: agent
host_filter: false
scrape_configs:
- job_name: metrics
metrics_path: '/metrics'
static_configs:
- targets: ['localhost:9115']
remote_write:
- basic_auth:
remote_write:
- basic_auth:
scrape_configs:
global:
scrape_interval: 60s
