[SOLVED] Getting HTTP 499 errors on a fresh kubernetes install (loki + promtail)
I’ve installed loki and promtail using the helm charts but grafana can’t read and promtail can’t write.
I’m using k3s:
kubectl version --short
Client Version: v1.25.4
Kustomize Version: v4.5.7
Server Version: v1.24.9+k3s2
10.42.4.126 - self-monitoring [19/Feb/2023:13:12:18 +0000]  499 "GET /loki/api/v1/query_range?start=1676805899181497587&end=1676812277182072987&query=%7Bstream%3D%22stdout%22%2Cpod%3D%22loki-canary-zllpv%22%7D&limit=1000 HTTP/1.1" 0 "-" "loki-canary/2.7.3" "-"
10.42.4.128 - - [19/Feb/2023:13:12:23 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
10.42.5.144 - - [19/Feb/2023:13:12:26 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
10.42.5.1 - - [19/Feb/2023:13:12:27 +0000]  200 "GET / HTTP/1.1" 2 "-" "kube-probe/1.24" "-"
10.42.4.128 - - [19/Feb/2023:13:12:34 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
10.42.5.1 - - [19/Feb/2023:13:12:37 +0000]  200 "GET / HTTP/1.1" 2 "-" "kube-probe/1.24" "-"
10.42.3.199 - - [19/Feb/2023:13:12:41 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
10.42.4.128 - - [19/Feb/2023:13:12:44 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
10.42.5.1 - - [19/Feb/2023:13:12:47 +0000]  200 "GET / HTTP/1.1" 2 "-" "kube-probe/1.24" "-"
10.42.3.198 - self-monitoring [19/Feb/2023:13:12:51 +0000]  499 "GET /loki/api/v1/tail?query=%7Bstream%3D%22stdout%22%2Cpod%3D%22loki-canary-wlc8x%22%7D HTTP/1.1" 0 "-" "Go-http-client/1.1" "-"
10.42.4.128 - - [19/Feb/2023:13:12:56 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
10.42.5.1 - - [19/Feb/2023:13:12:57 +0000]  200 "GET / HTTP/1.1" 2 "-" "kube-probe/1.24" "-"
10.42.5.144 - - [19/Feb/2023:13:13:00 +0000]  499 "POST /loki/api/v1/push HTTP/1.1" 0 "-" "GrafanaAgent/" "-"
Here is what the helm charts set up:
kubectl get all -n monitoring
NAME                                                          READY   STATUS    RESTARTS       AGE
pod/grafana-loki-grafana-agent-operator-6945fc54d7-xdn6k      1/1     Running   0              114m
pod/grafana-loki-logs-9g56b                                   2/2     Running   0              114m
pod/grafana-loki-logs-csw5n                                   2/2     Running   0              114m
pod/grafana-loki-logs-mdbhm                                   2/2     Running   0              114m
pod/grafana-promtail-4b87g                                    1/1     Running   0              18m
pod/grafana-promtail-7fknd                                    1/1     Running   0              19m
pod/grafana-promtail-cgzpr                                    1/1     Running   0              25m
pod/grafana-promtail-f8dpq                                    1/1     Running   0              19m
pod/grafana-promtail-nkvhr                                    1/1     Running   0              19m
pod/grafana-promtail-np9tr                                    1/1     Running   0              19m
pod/loki-canary-thwlv                                         1/1     Running   0              114m
pod/loki-canary-wlc8x                                         1/1     Running   0              114m
pod/loki-canary-zllpv                                         1/1     Running   0              114m
pod/loki-gateway-5d468df8-268bp                               1/1     Running   0              42m
NAME                                                     TYPE        CLUSTER-IP      EXTERNAL-IP   PORT(S)                      AGE
service/loki-canary                                      ClusterIP   10.43.249.205   <none>        3500/TCP                     114m
service/loki-gateway                                     ClusterIP   10.43.247.226   <none>        80/TCP                       43m
service/loki-memberlist                                  ClusterIP   None            <none>        7946/TCP                     114m
service/loki-read                                        ClusterIP   10.43.104.220   <none>        3100/TCP,9095/TCP            114m
service/loki-read-headless                               ClusterIP   None            <none>        3100/TCP,9095/TCP            114m
service/loki-write                                       ClusterIP   10.43.161.201   <none>        3100/TCP,9095/TCP            114m
service/loki-write-headless                              ClusterIP   None            <none>        3100/TCP,9095/TCP            114m
NAME                                                            DESIRED   CURRENT   READY   UP-TO-DATE   AVAILABLE   NODE SELECTOR   AGE
daemonset.apps/grafana-loki-logs                                3         3         3       3            3           <none>          114m
daemonset.apps/grafana-promtail                                 6         6         6       6            6           <none>          77m
daemonset.apps/loki-canary                                      3         3         3       3            3           <none>          114m
NAME                                                       READY   UP-TO-DATE   AVAILABLE   AGE
deployment.apps/grafana-loki-grafana-agent-operator        1/1     1            1           114m
deployment.apps/loki-gateway                               1/1     1            1           114m
NAME        DESIRED   CURRENT   READY   AGE
replicaset.apps/grafana-loki-grafana-agent-operator-6945fc54d7       1         1         1       114m
replicaset.apps/loki-gateway-5b5994874b                              0         0         0       46m
replicaset.apps/loki-gateway-5d468df8                                1         1         1       114m
NAME                                                               READY   AGE
statefulset.apps/loki-read                                         0/3     114m
statefulset.apps/loki-write                                        0/3     114m
The only values I changed were my storage class:
    loki:
      persistence:
        enabled: true
        storageClass: cephfs
and the tolerations in promtail:
    tolerations:
      - key: CriticalAddonsOnly
        operator: Exists
So it is a pretty much a vanilla install.
What am I missing?
I found this gist, and it seems to be exactly what I am seeing but I don’t know how I can modify the helm chart on the fly or make the changes he suggests.
Appears to be fixed in a future version.
