Hi All, Please help me!
I can’t send alerts to slack using alertmanager.
tree /etc/loki/
/etc/loki/
├── config.yaml
├── rules
│ └── alerts.yaml
└── rulestorage
2 directories, 2 files
alertmanager config
cat /etc/alertmanager/alertmanager.yaml
route:
group_wait: 10s
group_by: ['job', 'severity', 'instance', 'region', 'hostname', 'category']
group_interval: 30s
repeat_interval: 1h
receiver: slack
receivers:
- name: slack
slack_configs:
- api_url: "https://hooks.slack.com/services/___slack_token___"
send_resolved: True
channel: "alarms"
color: '{{ if eq .Status "firing" }}danger{{ else }}good{{ end }}'
pretext: '{{ .CommonAnnotations.summary }}'
text: |-
{{ range .Alerts }}
*Severity:* {{ .Labels.severity }}
*Alert:* {{ .Annotations.summary }}
*Description:* {{ .Annotations.description }}
*Region:* {{ .Labels.region }}
*IP:* {{ .Labels.instance }}
*Hostname:* {{ .Labels.hostname }}
*Details:* {{ .Annotations.dashboard }}
*Dashboard:* {{ .Annotations.dashboard }}
*WIKI:* {{ .Annotations.wiki }}
{{ range .Labels.SortedPairs }} • *{{ .Name }}:* `{{ .Value }}`
{{ end }}
{{ end }}
loki config
cat config.yaml
auth_enabled: false
server:
http_listen_port: 3100
ingester:
lifecycler:
address: 127.0.0.1
ring:
kvstore:
store: inmemory
replication_factor: 1
final_sleep: 0s
chunk_idle_period: 1h
max_chunk_age: 1h
chunk_retain_period: 30s
wal:
enabled: true
dir: /opt/loki/data/wal
# min_age: 5m
# max_age: 4h
schema_config:
configs:
store: boltdb-shipper
object_store: filesystem
schema: v11
index:
prefix: index_
period: 24h
storage_config:
boltdb_shipper:
active_index_directory: /opt/loki/data/boltdb-shipper-active
cache_location: /opt/loki/data/boltdb-shipper-cache
cache_ttl: 1h # Can be increased for faster performance over longer query periods, uses more disk space
shared_store: filesystem
filesystem:
directory: /opt/loki/data/chunks
compactor:
working_directory: /opt/loki/data/boltdb-shipper-compactor/
compaction_interval: 10m
retention_enabled: true
retention_delete_delay: 720h
retention_delete_worker_count: 150
limits_config:
reject_old_samples: true
reject_old_samples_max_age: 24h # TMP
retention_period: 720h
chunk_store_config:
max_look_back_period: 720h
ruler:
storage:
type: local
local:
directory: /etc/loki/rules
rule_path: /tmp/loki/rules-temp
alertmanager_url: http://10.144.46.50:9093
ring:
kvstore:
store: inmemory
enable_api: true
enable_alertmanager_v2: true
Alerts:
cat /etc/loki/rules/alerts.yaml
groups:
- name: patroni-alert
rules:
- alert: PatroniSwitchMaster
expr: 'count_over_time({job="systemd-journal"} |~ "fail" [1m]) > 1'
for: 1m
labels:
severity: warning
annotations:
summary: "alert"
description: "alert desc"
details: ""
dashboard: ""
wiki: ""
where can i wrong?
