Sni-pnp-database not connecting with pnp4nagios
  • click on save and test on sni-pnp-database
    configuring url to https://xx.xxx.xxx.xx:xxxx/pnp4nagios
    selecting Basic Auth
    entered user and password
    skip TLS verify
  • What happened?
    Datasource not connected
    400 Bad request
    connect successfully
    grafana.log Authentication to data source failed 401 Unauthorized
    This serve could not verify that you are authorized t access the document requested. Either you supplied the wrong credentials (e.g. bad password) or your browser doesn’t understand to supply the credentials required.
“request Completed” method=GET path=/api/datasources/proxy/uid/xxxxxxx/index.php/api
It is important to note that a curl with the associated userid and password works perfectly and return a response as expected.
    All instructions were followed from both the nagios pnp4 nagios install and I can get all the metrics displayed correctly when I attempt to view through a browser.
Here are the directions I used
Nagios Core - Using Grafana With PNP4Nagios
Nagios Core - Performance Graphs Using PNP4Nagios
PNP plugin for Grafana | Grafana Labs
Any help appreciated. No matter what parameters I put in the plugin I cannot get the datasource to save and test
I am using sni-pnp-datasource-2.1.0
Hi @bradyma this forum is about plugin development not about general plugin support.
I advice you to post this in the Github repository of the Sni-pnp-datasource
