Slow Query in Grafana Loki Self Hosted vs Grafana Cloud
Hi team,
I’m running Loki using the SimpleScalable mode on EKS, ingesting around 10 million log lines per day (~5GB/day).
However, query performance is significantly slower compared to Grafana Loki Cloud, even though I’ve already tuned many parameters.
Below is my current configuration (simplified). I would like guidance on whether any of these settings are incorrect or not. Thank you
deploymentMode: SimpleScalable
global:
  dnsNamespace: kube-system
  clusterDomain: cluster.local
loki:
  server:
    grpc_server_max_recv_msg_size: 209715200 #200MB
    grpc_server_max_send_msg_size: 209715200 #200MB
    grpc_server_max_concurrent_streams: 2000
    grpc_server_keepalive_timeout: 60s
    grpc_server_num_workers: 8
    http_server_read_timeout: 2m
    http_server_write_timeout: 2m
    http_server_idle_timeout: 2m
  auth_enabled: false
  schemaConfig:
    configs:
        store: tsdb
        object_store: s3
        schema: v13
        index:
          prefix: loki_index_
          period: 1d
  commonConfig:
    replication_factor: 2
  storage:
    type: s3
    bucketNames:
      chunks: grafana-loki-abcdef
      ruler: grafana-loki-abcdef
      #admin: grafana-loki-abcdef
    s3:
      region: ap-southeast-3
      insecure: false
  compactor:
    # Need to be enabled for retention to work
    retention_enabled: true
    # how long to wait before deleting the data
    retention_delete_delay: 2h
    delete_request_store: s3
  bloom_build:
    enabled: true
    planner:
      planning_interval: 3h
    builder:
      planner_address: loki-backend.loki.svc.cluster.local:9095
  # Configuration block for bloom filtering.
  bloom_gateway:
    enabled: true
    client:
      addresses: loki-backend.loki.svc.cluster.local:9095
  limits_config:
    bloom_creation_enabled: true
    bloom_split_series_keyspace_by: 1024
    bloom_gateway_enable_filtering: true
    ingestion_rate_strategy: local
    shard_streams:
      enabled: true
      desired_rate: 4194304 #4MiB
    allow_structured_metadata: true
    discover_log_levels: true
    #discover_service_name: [kubernetes_container_name]
    volume_enabled: true
    retention_period: 30d # 28 days retention
    split_queries_by_interval: 1d
    unordered_writes: true
    max_query_series: 1000000 # 10000 unique series by metric query
    max_streams_per_user: 1000 # 1000 streams per user
    max_entries_limit_per_query: 10000
    max_global_streams_per_user: 1000000
    max_query_parallelism: 240 # Maximum number of queries that can be executed in parallel
    max_concurrent_tail_requests: 500 # Maximum number of concurrent tail requests
    tsdb_max_query_parallelism: 400 # Maximum number of queries that can be executed in parallel for TSDB
    tsdb_max_bytes_per_shard: 2GB # Maximum bytes per shard for TSDB
    max_line_size: 256000 # 256KB
    max_line_size_truncate: true # Truncate lines that are too long
    # Precompute chunks for TSDB, This can improve query performance at the
    # cost of increased memory usage by computing chunks once during planning,
    # reducing index calls.
    tsdb_precompute_chunks: true
    query_timeout: 10m # 10 minutes
    ingestion_rate_mb: 20 # Increase per-tenant rate (MB/sec)
    ingestion_burst_size_mb: 30 # Allow short bursts
    per_stream_rate_limit: 30MB # Maximum byte rate per second per stream
    per_stream_rate_limit_burst: 50MB # Maximum burst bytes per stream
    max_query_bytes_read: 600GB # Maximum bytes read per query
    max_querier_bytes_read: 600GB # Maximum bytes read per querier
    max_query_lookback: 7d # Maximum lookback period for queries
  memcached:
    chunk_cache:
      enabled: true
      host: loki-chunks-cache.loki.svc.cluster.local
      service: loki-chunks-cache
      batch_size: 256
      parallelism: 20
    results_cache:
      enabled: true
      host: loki-results-cache.loki.svc.cluster.local
      service: loki-results-cache
      default_validity: 12h
  ingester:
    chunk_encoding: snappy
    chunk_block_size: 262144 # 512KiB
    chunk_target_size: 2097152 # 2MiB
    lifecycler:
      # Consider setting this to false to only check the health of the ingester itself, reducing the waiting time
      readiness_check_ring_health: false
  tracing:
    enabled: false
  pattern_ingester:
    enabled: true
  frontend:
    log_queries_longer_than: 5s
    grpc_client_config:
      grpc_compression: snappy
      max_recv_msg_size: 2097152000 #200MB
      max_send_msg_size: 2097152000 #200MB
  query_range:
    align_queries_with_step: true
    cache_results: true
    cache_instant_metric_results: true
    parallelise_shardable_queries: true
    max_retries: 5
    volume_results_cache:
      cache:
        memcached:
          batch_size: 64
          parallelism: 8
        memcached_client:
          addresses: loki-results-cache.loki.svc.cluster.local:11211
          max_idle_conns: 16
          timeout: 200ms
    results_cache:
      cache:
        # We're going to use the in-process "FIFO" cache
        enable_fifocache: true
        fifocache:
          max_size_bytes: 2GB
          validity: 12h
      compression: snappy
  querier:
    # Default is 4, if you have enough memory and CPU you can increase, reduce if OOMing
    max_concurrent: 100
  query_scheduler:
      max_outstanding_requests_per_tenant: 1000
      grpc_client_config:
        max_recv_msg_size: 1.048576e+11
        max_send_msg_size: 1.048576e+11
chunksCache:
  enabled: true
  replicas: 1
  defaultValidity: 1h
  maxItemMemory: 10
  persistence:
    enabled: true
    storageClass: ebs-sc-encrypted
  # allocated memory for chunks cache
  # https://github.com/grafana/loki/blob/main/production/helm/loki/templates/memcached/_memcached-statefulset.tpl#L101
  allocatedMemory: 13000 # 13GB
  affinity:
    nodeAffinity:
      requiredDuringSchedulingIgnoredDuringExecution:
        nodeSelectorTerms:
        - matchExpressions:
          - key: topology.kubernetes.io/zone
            operator: In
            values:
            - ap-southeast-3c
resultsCache:
  enabled: true
  maxItemMemory: 10
  persistence:
    enabled: true
  resources:
    limits:
      cpu: 1
      memory: 1Gi
    requests:
      cpu: 5m
      memory: 50Mi
  affinity:
    nodeAffinity:
        nodeSelectorTerms:
        - matchExpressions:
            operator: In
            values:
            - ap-southeast-3c
memcached:
  extraArgs:
    log.level: warn
  resources:
    limits:
      cpu: 1
      memory: 8Gi
    requests:
      cpu: 5m
      memory: 50Mi
memcachedExporter:
  enabled: true
  extraArgs:
    log.level: info
  resources:
    limits:
      cpu: 1
      memory: 2Gi
    requests:
      cpu: 5m
      memory: 50Mi
test:
  enabled: false
lokiCanary:
  enabled: false
storage_config:
  aws:
    bucketnames: grafana-loki-abcdef
    s3forcepathstyle: false
    backoff_config:
      min_period: 2s
      max_period: 5s
      max_retries: 5
  tsdb_shipper:
    active_index_directory: /data/loki/tsdb-index
    cache_location: /data/loki/tsdb-cache
    cache_ttl: 12h
    flush_interval: 10m
    object_store: s3
    bucket: grafana-loki-abcdef
chunk_store_config:
  chunk_cache_config:
    memcached:
      batch_size: 64
      parallelism: 8
    memcached_client:
      addresses: loki-chunks-cache.loki.svc.cluster.local:11211
      max_idle_conns: 16
      timeout: 200ms
serviceAccount:
  create: true
  annotations:
    "eks.amazonaws.com/role-arn": "arn:aws:iam::xxx:role/LokiRole"
backend:
  persistence:
    enabled: true
  affinity:
    nodeAffinity:
        nodeSelectorTerms:
        - matchExpressions:
            operator: In
            values:
            - ap-southeast-3c
  replicas: 2
  resources:
    limits:
      cpu: 1
      memory: 4Gi
    requests:
      cpu: 10m
      memory: 50Mi
read:
  autoscaling:
    enabled: true
    minReplicas: 3
    maxReplicas: 15
     targetCPUUtilizationPercentage: 80
     targetMemoryUtilizationPercentage: 80
  replicas: 15
  resources:
    limits:
      cpu: 1
      memory: 6Gi
    requests:
      cpu: 10m
      memory: 50Mi
    # affinity:
    #   podAntiAffinity: {}
write:
  persistence:
    enabled: true
  affinity:
    nodeAffinity:
        nodeSelectorTerms:
        - matchExpressions:
            operator: In
            values:
            - ap-southeast-3c
  replicas: 2
  resources:
    limits:
      cpu: 1
      memory: 6Gi
    requests:
      cpu: 25m
      memory: 250Mi
gateway:
  autoscaling:
    enabled: true
    minReplicas: 2
    maxReplicas: 5
  nginxConfig:
    clientMaxBodySize: 200M
  affinity:
    nodeAffinity:
        nodeSelectorTerms:
        - matchExpressions:
            operator: In
            values:
            - ap-southeast-3c
  resources:
    limits:
      cpu: 1
      memory: 2Gi
    requests:
      cpu: 10m
      memory: 50Mi
The first thing I would do is change “max_global_streams_per_user: 1000000” to a much smaller number. The default value is 5000 and you’re running at 200x that number, which is way past the limit that will cause performance issues. Fewer streams generally leads to better performance.
Is it possible if we can get the spec of loki cluster in the grafana cloud?
There are multiple clusters in Grafana Cloud, each tuned to support the customers that are hosted on that cluster.
But I can tell you that “max_global_streams_per_user:” is usually set to 80,000 streams for larger customers and over 200,000 streams is known to cause performance issues, so we’ve set that as a hard limit that Grafana will not go above. Which is why I suggested changing that value and seeing if that helps.
Will look at it thank you
