I am trying to get current value from query in Slack message but unfortunately I am getting {{ humanize $values.A.Value }} instead.
My Slack message template:
{{ define "alert_severity_prefix_emoji" -}}
{{- if ne .Status "firing" -}}
:white_check_mark:
{{- else if eq .CommonLabels.severity "critical" -}}
:red_circle:
{{- else if eq .CommonLabels.severity "warning" -}}
:warning:
{{- end -}}
{{- end -}}
{{ define "slack.title" -}}
{{ template "alert_severity_prefix_emoji" . }}
[{{- .Status | toUpper -}}{{- if eq .Status "firing" }} x {{ .Alerts.Firing | len -}}{{- end }}]: {{ .CommonLabels.alertname -}}
{{- end -}}
{{- define "slack.text" -}}
{{- range .Alerts -}}
{{ if gt (len .Annotations ) 0 }}
*Description*: {{ .Annotations.description }}
*Instance*:
{{ range .Labels.SortedPairs }}{{ if or (eq .Name "env") (eq .Name "instance") }}• {{ .Name }}: `{{ .Value }}`
{{ end }}{{ end }}
*Silence alert*: {{ .SilenceURL }}
*Go to dashboard*: {{ .DashboardURL }}
*Go to panel directly*: {{ .PanelURL }}
{{ end }}
{{ end }}
{{ end }}
Alert configuration:
what I am doing wrong?
