Hi, I tried to build an slack alert notification in grafana and based on the query value B and set a different description in annotation. I used the { if $values.B X} but it does not achieved what I want. I have one of the alert rule below and if anyone can help to solve it?
{{ define “slack.print_alert” -}}
{{ if .Value.B 2 }}
One of the Server Offline
{{ else if .Value.B 22 }}
All the Servers in the DataCenter Offline!
{{ else }}
There are unknown alerts
{{ end }}
{{- end }}
Hi!
Is it possible you forgot the eq
operator?
{{ if eq .Values.B 2.0 }}
The syntax you are using in your template for the Slack alert notification in Grafana is not correct.
{{ define "slack.print_alert" -}}
One of the Servers is Offline
{{ else if eq .Values.B 22.0 }}
All the Servers in the DataCenter are Offline!
{{ else }}
{{ end }}
{{- end }}
In the corrected template, the eq
function is used to compare the value of .Values.B
with the specified values (2 and 22).
Update based on @georgerobinson advise.
A couple of corrections on your otherwise great answer!
.Value
needs to be .Values
2
and 22
need to be 2.0
and 22.0
because Go templates won’t allow comparing a float to an int
Thanks for the great help!! The alert notification work perfectly!
Thanks. It worked and now I have a better understanding on the Go Template language.
