Singlestat math, how to format result as percentage?
I’m using singlestat math panel to calculate underpressure percentage? Is there anyway to format result as percentage?
This should show 5,9%. Now general format shows 0.0599
Hello mattirantakari!
Yes, it is possible to format result as percentage in the singlestat panel:
  1. Choose to edit the panel
  2. Go to Visualization tab/section
  3. In Unit input, choose percent(0-1.0)
Perfect! Thank you it works.
Hi
I have the same situation here. I have sensor data that shows both in the stat panel and a graph. How can I change the numeric data from the sensor to in percentage instead?
@peshawag Not sure if I understand your question, but are you trying to display something like this?
Yes, that is what I meant
