Question: Having two axis results in having two thresholds, is there any way to only have one threshold for one of the two axis?
Version: V8.2.2
Example: threshold is set to 98 but shows up on my left and right axis
Hello
and welcome to the forum, @iankoegelenberg
Try setting your thresholds inside the override feature. Then you should be able to set thresholds for specific fields, and also choose how to display them (off completely, line, fill, etc)
I don’t think you can have the thresholds appear and not have the line cross the entire graph, where it will “connect” will any y axes on the opposite side
