Hello
I’m developing several custom plugins based on the plugin template provided in the documentation (“https://github.com/grafana/simple-angular-panel ”). In my project I would like to use a single repository for all of my plugins. I’m approaching this by the yarn workspaces. Right now, the proper workspace structure is created (due to https://classic.yarnpkg.com/en/docs/cli/workspaces/ ), but the grafana-toolkit scripts are failing to build template plugins. There is a problem with the script paths.
So far I’ve tried it on Windows, with this command:
yarn install
yarn workspaces run build
Have anyone tried to develop his own plugins with similar approach? Any help will be much appeciated.
Hi!
Could you provide the errors that grafana-toolkit outputs? This might also be a related to Windows paths, have you tried it on another operating system?
/Tobias Skarhed
zero88
January 8, 2021, 7:09am
3
Hi @skarhed ,
I tried with grafana-toolkit, plugin datasource, yarn workspace
When building in workspace root project, toolkit show errors
Toolkit version: 7.3.6
$ yarn workspace test-datasource build
yarn workspace v1.22.5
yarn run v1.22.5
$ grafana-toolkit plugin:build
✔ Preparing
⠙ Linting
/home/node/modules/datasource/src/ConfigEditor.tsx
13:3 error Insert `··` prettier/prettier
14:5 error Insert `····` prettier/prettier
15:1 error Replace `····` with `········` prettier/prettier
16:1 error Replace `······` with `············` prettier/prettier
17:1 error Insert `······` prettier/prettier
18:1 error Replace `····` with `········` prettier/prettier
19:1 error Insert `····` prettier/prettier
20:3 error Insert `··` prettier/prettier
22:1 error Insert `··` prettier/prettier
23:1 error Insert `··` prettier/prettier
24:1 error Replace `····` with `········` prettier/prettier
25:5 error Insert `····` prettier/prettier
26:1 error Replace `······` with `············` prettier/prettier
27:1 error Replace `······` with `············` prettier/prettier
28:1 error Replace `········` with `················` prettier/prettier
29:7 error Insert `······` prettier/prettier
30:1 error Insert `····` prettier/prettier
31:3 error Insert `··` prettier/prettier
33:1 error Insert `··` prettier/prettier
34:1 error Insert `····` prettier/prettier
35:5 error Insert `····` prettier/prettier
36:1 error Replace `······` with `············` prettier/prettier
37:1 error Replace `······` with `············` prettier/prettier
38:1 error Replace `········` with `················` prettier/prettier
39:9 error Insert `········` prettier/prettier
40:1 error Replace `······` with `············` prettier/prettier
41:1 error Insert `······` prettier/prettier
42:1 error Replace `········` with `················` prettier/prettier
43:9 error Insert `········` prettier/prettier
44:1 error Insert `······` prettier/prettier
45:5 error Insert `····` prettier/prettier
46:3 error Insert `··` prettier/prettier
48:1 error Insert `··` prettier/prettier
49:5 error Insert `····` prettier/prettier
50:1 error Replace `····` with `········` prettier/prettier
51:1 error Insert `····` prettier/prettier
53:5 error Insert `····` prettier/prettier
54:1 error Replace `······` with `············` prettier/prettier
55:1 error Replace `········` with `················` prettier/prettier
56:1 error Replace `··········` with `····················` prettier/prettier
57:1 error Replace `············` with `························` prettier/prettier
58:1 error Replace `············` with `························` prettier/prettier
59:1 error Replace `············` with `························` prettier/prettier
60:1 error Replace `············` with `························` prettier/prettier
61:1 error Replace `············` with `························` prettier/prettier
62:1 error Replace `············` with `························` prettier/prettier
63:11 error Insert `··········` prettier/prettier
64:1 error Replace `········` with `················` prettier/prettier
66:1 error Insert `········` prettier/prettier
67:11 error Insert `··········` prettier/prettier
68:1 error Replace `············` with `························` prettier/prettier
69:1 error Replace `··············` with `····························` prettier/prettier
70:15 error Insert `··············` prettier/prettier
71:1 error Replace `··············` with `····························` prettier/prettier
72:1 error Insert `··············` prettier/prettier
73:1 error Replace `··············` with `····························` prettier/prettier
74:1 error Replace `··············` with `····························` prettier/prettier
75:1 error Replace `··············` with `····························` prettier/prettier
76:1 error Replace `··············` with `····························` prettier/prettier
77:13 error Insert `············` prettier/prettier
78:1 error Replace `··········` with `····················` prettier/prettier
79:1 error Replace `········` with `················` prettier/prettier
80:1 error Replace `······` with `············` prettier/prettier
81:5 error Insert `····` prettier/prettier
82:1 error Insert `··` prettier/prettier
/home/node/modules/datasource/src/DataSource.ts
4:3 error Insert `··` prettier/prettier
5:1 error Replace `··` with `····` prettier/prettier
6:1 error Replace `··` with `····` prettier/prettier
7:1 error Insert `··` prettier/prettier
8:1 error Replace `··` with `····` prettier/prettier
9:1 error Insert `··` prettier/prettier
15:3 error Insert `··` prettier/prettier
16:1 error Insert `····` prettier/prettier
17:3 error Insert `··` prettier/prettier
19:1 error Insert `··` prettier/prettier
20:5 error Insert `····` prettier/prettier
21:1 error Replace `····` with `········` prettier/prettier
22:1 error Replace `····` with `········` prettier/prettier
25:1 error Insert `····` prettier/prettier
27:1 error Insert `······` prettier/prettier
28:9 error Insert `········` prettier/prettier
29:9 error Insert `········` prettier/prettier
30:1 error Replace `··········` with `····················` prettier/prettier
31:1 error Replace `··········` with `····················` prettier/prettier
32:9 error Insert `········` prettier/prettier
33:1 error Replace `······` with `············` prettier/prettier
34:1 error Replace `····` with `········` prettier/prettier
36:1 error Insert `····` prettier/prettier
37:3 error Insert `··` prettier/prettier
39:1 error Insert `··` prettier/prettier
40:5 error Insert `····` prettier/prettier
41:5 error Insert `····` prettier/prettier
42:1 error Replace `······` with `············` prettier/prettier
43:1 error Replace `······` with `············` prettier/prettier
44:5 error Insert `····` prettier/prettier
45:1 error Insert `··` prettier/prettier
/home/node/modules/datasource/src/QueryEditor.tsx
14:3 error Insert `··` prettier/prettier
15:5 error Insert `····` prettier/prettier
16:1 error Replace `····` with `········` prettier/prettier
19:1 error Replace `··` with `····` prettier/prettier
22:1 error Insert `····` prettier/prettier
23:5 error Insert `····` prettier/prettier
24:1 error Insert `··` prettier/prettier
26:3 error Insert `··` prettier/prettier
27:1 error Insert `····` prettier/prettier
28:1 error Replace `····` with `········` prettier/prettier
30:5 error Insert `····` prettier/prettier
31:1 error Insert `······` prettier/prettier
33:1 error Replace `··········` with `····················` prettier/prettier
34:1 error Replace `··········` with `····················` prettier/prettier
35:1 error Insert `··········` prettier/prettier
36:1 error Replace `··········` with `····················` prettier/prettier
37:1 error Replace `··········` with `····················` prettier/prettier
38:1 error Replace `··········` with `····················` prettier/prettier
40:1 error Replace `········` with `················` prettier/prettier
41:1 error Replace `··········` with `····················` prettier/prettier
42:1 error Replace `··········` with `····················` prettier/prettier
43:1 error Insert `··········` prettier/prettier
44:1 error Replace `··········` with `····················` prettier/prettier
45:1 error Replace `··········` with `····················` prettier/prettier
46:1 error Insert `········` prettier/prettier
47:7 error Insert `······` prettier/prettier
48:5 error Insert `····` prettier/prettier
49:1 error Insert `··` prettier/prettier
/home/node/modules/datasource/src/module.ts
8:3 error Insert `··` prettier/prettier
/home/node/modules/datasource/src/types.ts
16:3 error Insert `··` prettier/prettier
✖ 138 problems (138 errors, 0 warnings)
138 errors and 0 warnings potentially fixable with the `--fix` option.
Trace: Error: 138 linting errors found in 5 files
at /home/node/node_modules/@grafana/toolkit/src/cli/tasks/plugin.build.js:98:31
at step (/home/node/node_modules/@grafana/toolkit/node_modules/tslib/tslib.js:140:27)
at Object.next (/home/node/node_modules/@grafana/toolkit/node_modules/tslib/tslib.js:121:57)
at fulfilled (/home/node/node_modules/@grafana/toolkit/node_modules/tslib/tslib.js:111:62)
at processTicksAndRejections (internal/process/task_queues.js:93:5)
at /home/node/node_modules/@grafana/toolkit/src/cli/utils/useSpinner.js:25:29
at Object.throw (/home/node/node_modules/@grafana/toolkit/node_modules/tslib/tslib.js:121:57)
at rejected (/home/node/node_modules/@grafana/toolkit/node_modules/tslib/tslib.js:112:69)
✖ 138 linting errors found in 5 files
error Command failed with exit code 1.
info Visit https://yarnpkg.com/en/docs/cli/run for documentation about this command.
error Command failed.
Exit code: 1
Command: /usr/local/bin/node
Arguments: /opt/yarn-v1.22.5/lib/cli.js build
Directory: /home/node/modules/datasource
Output:
info Visit https://yarnpkg.com/en/docs/cli/workspace for documentation about this command.
