I want to know I created a graphics, due to I monitor server has a lot of, but I want it in real time according to the current usage of the top ten largest in all of the server, such as monitoring all server network card, in the current network maximum flow of the top ten, or CPU, how should I configure?
You can do this in a bout a thousand different ways depending on your data source and what data collector you use, so without any info on your setup it’s impossible to answer this question
