I am running Grafana 5.2.4 on CentOS 7.5 Linux OS. I am referring to the below URLs for setting warning and critical thresholds in Grafana.
http://docs.grafana.org/alerting/rules/
http://docs.grafana.org/alerting/notifications/
I am finding it difficult to set it. For example setting 80 % warning and 90% critical thresholds for Memory consumption of remote client nodes if there are 10 client nodes which are monitored by Telegraf/Grafana and InfluxDB server.
80 % warning and 90% critical thresholds of total Physical Memory which is 16 GB on all 10 remote client nodes for example.
Any help will be highly appreciable. Thanks in Advance.
Best Regards,
Kaushal
