Grafana 10.4.1 on windows 10
- Trying to set up auto log in into Grafana on localhost from an iframe inside a web application.
What happened?
- No auto login was made, currently I can “bypass” with anonymous login.
- to get my current logged in user details and log in into Grafana.
[server]
- protocol = http
- http_addr = 127.0.0.1
- http_port = 8080
- domain = 127.0.0.1
- enforce_domain = false
[security]
- allow_embedding = true
[auth]
- login_cookie_name = grafana_session
- disable_login = false
- login_maximum_inactive_lifetime_duration =
- login_maximum_lifetime_duration =
- token_rotation_interval_minutes = 10
- disable_login_form = false
- api_key_max_seconds_to_live = -1
[auth.anonymous]
- enabled = true
- org_name = Main Org.
- org_role = Viewer
[auth.basic]
- enabled = false
[auth.proxy]
- enabled = true
- header_name = X-WEBAUTH-USER
- header_property = username
- auto_sign_up = true
- sync_ttl = 60
- whitelist = 192.168.1.1, 192.168.2.1
- headers = Email:X-User-Email, Name:X-User-Name
- whitelist =
- headers =
- enable_login_token = false
- No.
