I would like to Setting up a PersistentVolume to run test. I am geting the following error:
level=error msg="The moduleSpecifier "/test/test.js" couldn’t be found on local disk. Make sure that you’ve specified the right path to the file. If you’re ru │
│ Stream closed EOF for k6-operator-system/run-k6-with-vars-initializer-vwccf (k6)
Below is my YAMLs. I am not sure what this means in the doc " When using a PersistentVolume , the operator will expect all test scripts to be contained within a directory named /test/" ? Can I please get some guidance here?
apiVersion: v1
kind: PersistentVolume
metadata:
spec:
capacity:
storage: 1Gi
accessModes:
- ReadWriteOnce
hostPath:
path: /mnt/data/k6-test-scripts
apiVersion: v1
kind: PersistentVolumeClaim
metadata:
spec:
accessModes:
- ReadWriteOnce
resources:
requests:
storage: 1Gi
apiVersion: k6.io/v1alpha1
kind: TestRun
metadata:
spec:
parallelism: 3
script:
volumeClaim:
file: test.js
runner:
env:
- name: USERS
value: '5'
# cleanup: "post"
