Setting time range from JavaScript
    V11.2.0
How can I set the time range from JavaScript? For instance, from an echarts panel or in the JavaScript console in Google Chrome. I want to be able to run a snippet of code to set the start or end of the time picker to a specific value.
Previous posts on this forum have suggested using angular selectors to get the time picker and set it, but angular has been removed in this version.
I can find the time picker singleton in the typescript library but can’t access it from the browser!
Thanks in advance for your help.
@linerider We have an example in documentation for Business Charts (ECharts)
Thank you, that’s perfect!
