I am using an eclipse hono instance for a cloud. This uses influxDB for the storing the metrics data and a Grafana instance for providing a dash board for visualizing the collected metrics data. I am sending data to this hono instance from 4 devices. However, the default graph board shows all of it on the same panel. How do I separate it onto multiple panels?
Just add as many panels as you need. Then on the metrics tab of each panel, in edit mode, add a WHERE statement to the DB query, so the results from DB are filtered by device. This should do the trick.
However, in the drop down available for the WHERE statement, I get only the data_type, host and tenant. I don’t seem to find a filter for the device.
I am attaching a snapshot for your reference:
Hi @vamsi3012
Sorry, I’m not a expert in InfluxDB at all. But: Looks to me like you needed the device’s name as a tag in the POST, so you can use it in a filter… Does this make sense?
Yes. Although in the POST command that you see, sensors 1-4 are the authentication IDs for the different devices. So I needed a filter that could make use of this so that I could separate the data.
Hi @vamsi3012
I’m not sure how InfluxDB handels these usernames xx@domain. It seem to strip the sensor name part…
You think it’s bad practice to use the sensor’s name for tagging?
Actually, Eclipse hono accepts data only via the authentication ID of the sensor and not the sensor name. So just following the rules that hono specifies.
