Is it possible to send a custom message - manually to a notifcation channel. Sometimes it may be usefull to infrom all users on specifid channel about planned activity or introduction of new alert.
Interesting use-case
the alerting system is not designed for that purpose but you can use Contact Point Testing feature to do that.
Thanks for the reply. Oh… looks like I’m on older grafana version where it’s called notification channels. Is it possible to edit the “test” message in newer versions?
Yes you’re free to specify any message\template
