I’m trying to send SMS via my OVH account.
If I use the WEBHOOK protocol in a contact point and only enter the URL (exemple):
ttps://www.ovh.com/cgi-bin/sms/http2sms.cgi?&account=XXXXXXX&login=XXXXXXX&password=XXXXXXX&from=XXXXXXX&to=XXXXXXX&message=XXXXXXX
During the test, Grafana tells me it’s OK, but I get nothing.
If I test the URL in my browser, it works.
Can you tell me if it’s possible to send only a URL with Grafana?
Thanks for your help
Vincent
Have you tried checking if the webhook needs any specific authentication?
