Send hostname and IP on alert message
I’m trying to make a notification template that sends the IP and the Hostname of the affected service that is alerting.
When I build the query (a simple query that shows if a service is running, for example), I can’t see the respecive labels with this information. Here’s is an example:
What i’m doing wrong? How can I see that info?
Hi @tdeltell
Instead of having the query in A and the classic condition in B, can you instead try:
A: query (same as you have now)
B: reduce
C: math expression
Something like this…
Thank you! I will try it and post the results
I have configured the alert as you told me and, although I already see the labels on the query result (such as host.ip or host.hostname ) i cannot use on the notification. As discussed in this post, I have configured a new annotation called AlertValues with the following content:
{{ with $values }}
{{ range $k, $v := . }}
   IP: {{$v.Labels.host.ip}}
   Hostname: {{$v.Labels.host.hostname}}
   Alerting value: {{ $v }}
{{ end }}
{{ end }}
How can I use that variables on the notification? If i configure the template as in the post mentioned:
{{ define "myalert" }}
  [{{.Status}}] {{ .Labels.alertname }}
  {{ .Annotations.AlertValues }}
{{ end }}
{{ define "mymessage" }}
  {{ if gt (len .Alerts.Firing) 0 }}
    {{ len .Alerts.Firing }} firing:
    {{ range .Alerts.Firing }} {{ template "myalert" .}} {{ end }}
  {{ end }}
  {{ if gt (len .Alerts.Resolved) 0 }}
    {{ len .Alerts.Resolved }} resolved:
    {{ range .Alerts.Resolved }} {{ template "myalert" .}} {{ end }}
  {{ end }}
{{ end }}
It shows nothing.
Viewing the logs i have the following errors:
logger=ngalert t=2023-04-11T14:50:01.98+0200 lvl=eror msg="error in expanding template" name=description value="{{$v.Labels.agent.name}} CPU is overloaded!" err="error parsing template __alert_CPU Usage Alert: template: __alert_CPU Usage Alert:1: undefined variable \"$v\""
logger=ngalert t=2023-04-11T14:50:01.98+0200 lvl=eror msg="error in expanding template" name=IP value="{{ index $values.A.Labels “host.ip\" }}" err="error parsing template __alert_CPU Usage Alert: template: __alert_CPU Usage Alert:1: unrecognized character in action: U+201C '“'"
Can you help me to continue?
Thank you
I solved this using that templates:
{{ define “slack.title” -}}
{{ template “alert_severity_prefix_emoji” . }}
[{{- .Status | toUpper -}}{{- if eq .Status “firing” }} x {{ .Alerts.Firing | len -}}{{- end }} ] || {{ .CommonLabels.alertname -}}
{{- end -}}
{{- define “slack.text” -}}
{{- range .Alerts -}}
{{ if gt (len .Annotations) 0 }}
Summary: {{ .Annotations.summary }}
{{- if index .Annotations “description” }}
Description: {{ index .Annotations “description” }}{{ end }}
{{- if index .Annotations “Value” }}
Value: {{ .Annotations.Value }}{{ end }}
{{ end }}
{{ end }}
{{ end }}
Hello! Did you solved this?
I cannot retrieve hostname of my servers, could you please elaborate more?
