Hello friends,
Is there a way that the Alerts from Grafana is to be send either to file or to an API?
If yes, do you have sample of configuration for it?
Thank you so much,
Humphrey
Hello friends,
Thank you so much,
Humphrey
Hi @hheynen,
Welcome to the
community support forums !!
Yes, it is possible to do this via HTTP API. you can check the documentation regarding it i.e. :
