Hello. is there a way to selectively discardResponse body? I have a test script which makes a call to retrieve a token (from the response), this token is passed as part of the request header for the service under test. which I do not need the response body…
get_token I need the response. get_stuff_from_api I do not need the response body. how can I use the options precedence to make the script sure get_token returns the body (currently set in a global options.js file) , then set there response body option to false for the functions in group()?
pseudo code…
var res = get_token(stuff);
var res_json = JSON.parse(res.body);
api_token = res_json['access_token'];
THIS IS WHERE I NEED THE RESPONSE BODY
// Below is the actual test case for the /account/me API endpoint
group("get_titles_by_id", function () {
var res = get_stuff_from_api(api_token);
// console.log(JSON.stringify(res));
