Hello guys! I’m trying to split results of testing for two scenarios. I use first example from Advanced Examples and getting combined results for both scenarios. I expected separate statistics for each scenario, or I wrongly understand this article…
The third example shows how the scenario names can be referenced in thresholds which will split out the results.
Thank you richmarshall for your reply.
I expected that all metrics will be grouped separately but it seems it is not so easy as I wish.
