Is it possible to set a threshold on multiple tags?
For example, usually one would do:
http_reqs{scenario:my_test}: [...]
For the single scenario tag.
But can one do something like:
http_reqs{scenario:my_test, status:200}: [...]
On both the scenario and status tags. Based on my testing, I wasn’t able to get this to work.
Hi @jhwj9617,
this use-case is already supported.
For example, I can run correctly a test with the thresholds
option set like this:
export let options = {
thresholds: {
'http_reqs{scenario:my_test,status:200}': ['count>20'],
Are you using the same syntax? Can you report more details about the error and/or the script that you’re executing, please?
sorry for late, late reply. marking solution, thanks.
