Scale is not machting the displayed value
    I’m running grafana inside a docker containe on an Unbuntu Machine
    grafana/grafana-oss:9.5.3
    Fixing the scale on this:
    https://i.imgur.com/EwMab0l.png
Quary looks like this:
sum by (server) (velocity_online_player{proxy_name=~"$proxy"})
  • What happened?
    The scale is about 2x the max value, and the graph is not maching the displayed value
    Nope
    Yes
    Nope
    Nope
make sure “Stack series” is “Off”
Thanks that fixed it.
