This error occurs when i enter the url and click save and test
http://192.168.102.133:9100
I try change url but it’s still like that
http://192.168.102.133:9100/metricsI don’t know fix it. pls help me
I’m running into the same error, sending logs between two hosts at AWS.
The first time I got the error, I’d forgotten to open a security group (port / network allow) rule between the two hosts. Now that I’ve done that, I can curl the remote server, and get the metrics data just fine.
However, setting up a local Prometheus install to the remote server doesn’t work, same error message you got.
I realize this is a Grafana forum, but as Google gave me just a few websites, and this was one of them, I figured I’d toss a bottle in the ocean.
For your problem, I’d say, check your networking setup. I tried hitting that same URL and got no results either. Your port is probably blocked.
== John ==
