Сross-request in query legend
Hi everyone!
I have several query graphs that receive data from Prometheus. They show information from different docker nodes, but the only information I can get from the query to set it in the Legend field is instance IP. This instance IPs are incomprehensible to a simple user. Therefore, I want to change Legend field values by using some other query in which I can find docker node name. I have such query, where I can find one Node name for one instance IP. But I have no idea how to put it all together.
So, here a real queries example:
  1. Graph query:
100 - (avg by (instance) (irate(node_cpu_seconds_total{instance=~“$node”,mode=“idle”}[5m])) * 100)
  1. The only Legend for this query:
{{instance}}
  1. The query, where I can find a good name (used in variables):
label_values(node_meta,node_name)
Is there any way to set a cross-request in a Legend field inside a query?
