Retention with TSDB
The compactor doesn’t seem to support tsdb-shipper but the docs say:
The Compactor retention will become the default and have long term support. It supports more granular retention policies on per tenant and per stream use cases.
Is that still accurate? Does the compactor support tsdb and if it doesn’t, should we be using Table Manager instead? If we shouldn’t be using the compactor and the Table Manager what’s the new recommended way to do retention?
