restricted access for users
Hi, I have a dashboard with a variable that is the clients I have.
When you filter by client, the data specific to that client is displayed using the inlfux DB.
My problem comes when I want to give a customer access so that he can only view his data. If I create a user to that dashboard, he could access the variable and see the data of any client. My question is if something happens to you to be able to register a user and only access their data.
Thank you very much,
Greetings,
Not with one dashboard.
You might be able to do it with folder permissions. You would have to give Viewer permissions to each user for only folder that contains their dashboard.
