I am trying to represent/show the network usage/behavior over the previous hours. Therefore I create the network topology in Grafana with the FlowCharting Plugin. The changes (implemented with thresholds) will now be shown at the moment they happen, which is great to observe the current network status. But I would like to have the option to see the networks behavior over the last few hours, not only the graphs for the different nodes. Ideally with a timeline where I can set specific moments.
I receive the data from NetXMS.
v8.1.6 (4a4083716c)
virtualize network behavior over previous hours, ideally with FlowCharting -
Currently with FlowCharting… -
What happened?
A GUI where i can choose different time moments, maybe with a timeline -
Grafana integration — NetXMS Administrator Guide (4.0.2092)
Flowcharting for Grafana | flowcharting-repository
h
