Hi all,
I’m trying to render a dashboard using the /render api; these are the steps I’m following as an initial attempt (Grafana v6.0.1, from inside a Docker container):
Find the dashboard’s uid and name:
curl 'localhost:3000/api/search'
Try to render it
curl 'localhost:3000/render/d-solo/UID/NAME?width=600&height=400&panelId=1'
I tried with other urls like /render/dashboard-solo/db endpoint and /render/dashboard/db but they both gave 301 errors when retrieving data (I think it had to do with this.)
Log output:
t=2019-06-12T21:43:53+0000 lvl=info msg=Rendering logger=rendering path="d-solo/UID/NAME?width=600&height=400&panelId=1"
t=2019-06-12T21:43:53+0000 lvl=eror msg="Could not find plugin definition for data source: "
t=2019-06-12T21:44:55+0000 lvl=info msg="Rendering timed out" logger=rendering
t=2019-06-12T21:44:55+0000 lvl=eror msg="Timeout error. You can set timeout in seconds with &timeout url parameter" logger=context userId=0 orgId=1 uname= error="Timeout error. You can set timeout in seconds with &timeout url parameter"
t=2019-06-12T21:44:55+0000 lvl=eror msg="Request Completed" logger=context userId=0 orgId=1 uname= method=GET path=/render/d-solo/UID/NAME status=500 remote_addr=127.0.0.1 time_ms=62029 size=1790 referer=
I’ve tried upping the timeout but I still get timeout errors.
Any idea what could be causing the issue?
Thanks!
