I use the Direct link rendered image button to render a pie chart image. The png result without legend info. Waht can I do to fix this problem?
What version of grafana and the pie chart panel are you using?
Grafana v5.0.4 and pie chart 1.2.0
was there a resolution to this issue ? have same problem
