I’m currently stuck with the Rename by regex function for a gauge panel…
So I have this gauge panel with multiple queries which are retrieving the same sort of data but from different hosts. For example: I have 10 gauges in one panel which all show Active connections. But these active connections are from different hosts. So I want to show the hostname of each query instead of Active connections.
I’m using the inofficial CheckMK plugin. The query of it looks like this:
> "request": {
> "method": "POST",
> "url": "api/datasources/proxy/13/cmk/check_mk/webapi.py?action=get_graph",
> "data": "request={\"specification\":[\"combined\",{\"context\":{\"host\":{\"host\":\"host-01"}},\"datasource\":\"services\",\"single_infos\":[\"host\"],\"graph_template\":\"METRIC_active\",\"presentation\":\"lines\"}],\"data_range\":{\"time_range\":[1660266335,1660309535]}}",
> "hideFromInspector": false
> "response": {
> "result_code": 0,
> "result": {
> "start_time": 1660266240,
> "end_time": 1660309440,
> "step": 120,
> "curves": [
> "line_type": "line",
> "color": "#a500ff",
> "title": "Active connections",
> "rrddata": [
> null,
> 0,
> 0,
> 0,
> 3,
> 3,
> 3,
> 3,
> 3,
> 3,
> 3
So I would like to have active connections replaced with hostname (in this case host-01)
Is this possible?
