I’m retrieving data from a Linux Node Exporter from Prometheus, and i try to limit the result to devices starting by /dev/sd.
Linux give a list like this:
/dev/sda1
/dev/sdb1
/tmpfs
etc…
I’ve tried the following query, which is valid on all RegEx online testers i’ve found: node_filesystem_avail_bytes{instance=“grafana.myserver.com:9182”,device=~"^/dev/sd"}
But Grafana give me this error:
“invalid parameter ‘query’: 1:90: parse error: unknown escape sequence U+002F ‘/’”
It doesn’t seems to like the . I’ve tried without them, but it return no result (but no error too)
I only want to retrieve /dev/sda1 and /dev/sdb1
Thank you
Christian
