Please avoid posting in the Grafana parent category. Whenever possible choose a subcategory.
Hello, I wanted to know that is there any way through which we can send data from Grafana to other sources like a database or something like that. (Synchronous Call)
THANK YOU!!
~ the grafana team
Welcome
What data from grafana do you want to send to another db?
As @yosiasz replied depends on the data you want to send. The Data Manipulation panel may help you.
I want to send Data of user profiles and other things like some statistical data like values of current, voltage, etc.
Hi @abhiswc29,
Welcome to the community support forums !!
I do not understand your question v.clearly but for getting the Grafana’s own data for visualisation, you can use the following documentation to set it up:
