Redirect Loop with nginx ingress & Kubernetes and url-subpath
    grafana/grafana Version 10.1.5
    I would like to be able to access Grafana when I go to url/grafana.
    The first thing I did was follow these instructions: Deploy Grafana on Kubernetes
    Then I created an Ingress for Grafana. Finally, I adapted the environment variables for Grafana: Behind a proxy
  • What happened?
    I am always redirected from url/grafana to url/grafana.
    I actually expect to see the login page.
ingress.yaml
apiVersion: networking.k8s.io/v1
kind: Ingress
metadata:
  namespace: grafana
  annotations:
    nginx.ingress.kubernetes.io/rewrite-target: /$2
spec:
  ingressClassName: nginx
  rules:
    - host: example.com
      http:
        paths:
          - path: /grafana(/|$)(.*)
            pathType: Prefix
            backend:
              service:
                port:
                  number: 3000
  tls:
    - hosts:
        - example.com
      secretName: secret-tls
grafana.yaml
apiVersion: apps/v1
kind: Deployment
metadata:
  labels:
    app: grafana
  namespace: grafana
spec:
  selector:
    matchLabels:
      app: grafana
  template:
    metadata:
      labels:
        app: grafana
    spec:
      securityContext:
        fsGroup: 472
        supplementalGroups:
          - 0
      containers:
        - name: grafana
          image: grafana/grafana:latest
          imagePullPolicy: IfNotPresent
          env:
            - name: GF_SERVER_DOMAIN
              value: "example.com"
            - name: GF_SERVER_ROOT_URL
              value: "https://example.com/grafana"
            - name: GF_SERVER_SERVE_FROM_SUB_PATH
              value: "true"
          ports:
            - containerPort: 3000
              protocol: TCP
          readinessProbe:
            failureThreshold: 3
            httpGet:
              path: /robots.txt
              port: 3000
              scheme: HTTP
            initialDelaySeconds: 10
            periodSeconds: 30
            successThreshold: 1
            timeoutSeconds: 2
          livenessProbe:
            failureThreshold: 3
            initialDelaySeconds: 30
            periodSeconds: 10
            successThreshold: 1
            tcpSocket:
              port: 3000
            timeoutSeconds: 1
          resources:
            requests:
              cpu: 250m
              memory: 750Mi
          volumeMounts:
            - mountPath: /var/lib/grafana
      volumes:
        - name: grafana-pv
          persistentVolumeClaim:
            claimName: grafana-pvc
apiVersion: v1
kind: Service
metadata:
  namespace: grafana
spec:
  ports:
    - port: 3000
      protocol: TCP
      targetPort: http-grafana
  selector:
    app: grafana
  sessionAffinity: None
  type: ClusterIP
    The logger does not show any new entries when I go to the page.
    See links attached above.
Many thanks for your help
The problem could be solved with some testing of the environment variables. Contrary to the instructions, GF_SERVER_SERVE_FROM_SUB_PATH must be set to false.
I did not have to adjust anything else.
