I am really now to Grafana and would like to know what i am doing wrong here. I can read a query as table but can´t plot it as a graph as it says “No graphable fields”.
My query is:
SELECT
reading_time AS "time",
value1
FROM "SensorData"
WHERE
$__timeFilter(reading_time)
ORDER BY 1
my table:
Can anyone explain me why i cant plot it?
Thnaks
To fix this you have to add a group by time. Look at the following image:
Hello, you were able to solve the problem I have the same problem ?
You might need to convert your data. Look at the structure of your database to check the type of your value column. In my case, it was a varchar which is literally “not graphable” but looks fine in the table. Grouping is a workaround (although to be honest, I don’t know why that works) but in my case it was much simpler to convert on the fly. Using the OP example:
SELECT
CONVERT(value1, FLOAT)
FROM "SensorData"
WHERE
Hope that helps a poor soul that wanders around the web trying to find out what is going on with his or her query…
I am experiencing the same problem.
I am taking the values from Influxdb. Not having specified any type of value by default Influx should save floats.
However, I can see the data in a table but I cannot plot them in a graph.
I am not sure how to sort this problem.
My query is rather simple:
SELECT “value” FROM “temperature” WHERE time >= now() - 3h and time <= now()
I need some help to fix this but I would love to understand why this is happening.
Thanks for helping
Upgraded to latest 8.1.1, I was on 8.0.1 working perfectly fine, now my simple query does not work but it did before, oh dear.
Any help, please?
