Read Json Log and Push reformated Json to Loki
I’m reading logs like:
{"timestamp":"2024-06-06T01:00:30.840+02:00","version":1.68,"country": "en"}
and like to transform it e.g. to:
{"timestamp":"2024-06-06T01:00:30.840+02:00","ver":1.68,"country": "en"}
How can I use loki.process stage to reformat the labels?
That’s the stage what I use:
loki.process "version_log" {
	forward_to = [loki.write.version_log.receiver]
	stage.json {
		expressions = {
			version		= "version",
	stage.labels {
		values = {
			"ver" = "version",
Thanks for your help
I would recommend you not to.
Thank you for your help. Then I will not do it.
