I use follow label_replace() promql when i create a Query(It is dicplaycorrectly when I run it in Prometheus ), but the legend can’t display correctly inGrafana.
Promql:
label_replace(container_memory_rss{container_label_com_docker_stack_namespace=“uat_app”}, “test”, “$1”, “name”, “(.*)\.[0-9a-z]{25,}”)
Grafana v8.0.3 (cae5c5e46b) -
I run it in Prometheus ,it display correctly -
What happened?
legend can’t display correctly -
