I want to use rate function for query elasticsearch data. how to do that?
Any suggestion?
Thanks
Any suggestion?
Thanks
Is there any way to do rate query for elasticsearch dta source. I would like to calculate network interface rate from raw data posted by metricbeat
Hi, did you find a solution?
I’m looking for the same thing.
Thank you, meanwhile i was able to solve it in another way.
My syslog-ng sends every 10m a message log to graylog with its stats, i then do some processing in graylog to create the fields d_graylog_processed, d_graylog_dropped, etc…
for example d_graylog_processed containers the number of messages that were processed by syslog-ng regarding the graylog destination on the last 10m.
I was able to make it work with sum and derivative.
I just added some overrides to hide the sum field and rename the derivative one.
great. Thanks for sharing
